I was going to fit a Cooler Master AquaTrident cpu cooler in my project parallel HEX, but after waiting over a month on a supplier to get me one, I've ran out of patience. I was happy to wait while I built the rest of the case, but now I'm ready to water cool, I need the components now. Nowhere in the UK has the AquaTrident in stock, so plan B.
I prefer the idea of 6/8mm tubing, and also the 1 port in, 2 ports out design of cpu water blocks. My water cooling circuit is designed around this, and looking for suitable water blocks has turned up null.
So my idea is to obtain an AquaComputer Cuplex XT and modify it to a 3 port design, a la:
All the plexi lid would need is a tapped 1/8" hole, but the base would need to be modified so the port that is the input on the original doesn't take some of the flow from the centre input. Instead it would take water away like the other outer port. Easy enough to do with the right tools (or know someone that has ) :
The top of the above would need a small wall inserted, but I don't have a pic of that to photochop .
The copper base needs no modification at all:
Clearance for tubing wouldn't be an issue if the correct fittings were used.
So, do you think I'm mad, would it be worth it, and should I try to alter (in some peoples opinion) perfection ?
