cellophane-noodles
- Aug 4, 2006
So, basically what I want for my partition system is this:
(320gb total)
C:\ - 30gb - windows
D:\ - 100gb - programs
E:\ - 190gb - data
The question is, where do I put the documents and settings folder which includes my documents? I was thinking I should put it in with the programs because some programs use the documents and settings app data, but then my documents would be in with the programs. Is there a way to have the documents and settings folder in one partition and the my documents folder in another? What's the best way to set this up?
One more thing, is there a good guide to nlite listing a bunch of things that aren't needed?
Thanks
(320gb total)
E:\ - 190gb - data
Thanks
