Okay, New Pics!
Pardon the dust.
Okay, after a couple of weeks of work, and 2 motherboards later, I have my computer up and running again.
Some of you might have seen my watercooled Stacker. I did not like that case very much, and it was to big. So, I decided to move to a smaller case, the Lian Li PC-V600.
In this transition, I wanted to keep as many of my WC parts as possible.
Stackers WC specs
DD D5 Pump
MicroRes
120.3 BIP
Swiftech Storm
DD Maze 4 GPU
1/2" ID 3/4" OD Tygon
V600 WC specs
DDC Ultra + clear top thing
MicroRes
120.3 BIP
Swiftech Storm
DDj Maze 4 GPU
1/4" ID 3/8" OD Tygon(I love this stuff)
This is a lot to fit in such a small case, so where to start?
Performance-PCS did a great job with the 120x3 radgrill install. I have neither the tools nor the skill to do this, so I was happy they could.
After this, I started putting stuff together. Sorry, no pics of that. First leak test was a failure. Second was good. The computer ran 1 day, after that, nothing.
Here, I have to put in a disclaimer for the v600 + rad on top. ATX mobos will not fit comfortably. They rad was touching my bottom(top) pci slot, and blocked my front panel connectors. I had to bend them to get it to fit, which is why this mobo died, I think. As it would not turn on.
I then ordered a new mobo, the boistar tforce mATX 754 board. This fit much better. Got everything installed, leak tested, went to turn in it on, and got nothing on my moniter. Turns out my vid card was dead. Which is why you see it unplugged in these pictures.
3 crappy pictures is all I got with my sisters camera. Batteries died, and I can find any AA battteries in the house... I did not resize these yet, so links only right now. Later today I will get more batteries, more pictures, and resize them.
Hopefully this will make the million(3) people pming my for pics happy.
Pardon the dust.
Stackers WC specs
DD D5 Pump
MicroRes
120.3 BIP
Swiftech Storm
DD Maze 4 GPU
V600 WC specs
MicroRes
120.3 BIP
Swiftech Storm
DDj Maze 4 GPU
