mind giving examples of equivalent, yet cheaper monitors?Cornflake said:Static is right. Also, input lag will be noticable on the desktop... not just in gaming. Besides, you can get a monitor of nearly the same quality for $100's cheaper. The 244t has got the best color accuracy, if you are a heavy graphic designer for example...
drizzt81 said:mind giving examples of equivalent, yet cheaper monitors?
thanks. And no, i could care less about component/ s-video inputs.Cornflake said:Sure. Is Component / S-video inputs a concern for you? If it is, that's going to limit your options.
The best monitor I know of, in that price range is the Acer AL2423W. I've mentioned this to many others latley also -- it's input lag is minimal, excellent colour reproduction and black levels. Even if the 244t didn't suffer from input lag... it's not worth paying $850 when this Acer I mentioned is $150 cheaper and a display nearly on par with the Syncmaster.
P.S. For those of you who don't notice the input lag... there are alot of factors involved. Fist, you couple people have mice like the G5 or Razer which are high-end mouses that are like 2,000dpi so that is over-compensating so you don't feel your mouse lagging as much. BUT even with those mouses, you are still going to have some lag. If you don't notice ANY, in my book you need an eye transplant.
samsung 244t when its avail.
Cornflake said:P.S. For those of you who don't notice the input lag... there are alot of factors involved. Fist, you couple people have mice like the G5 or Razer which are high-end mouses that are like 2,000dpi so that is over-compensating so you don't feel your mouse lagging as much. BUT even with those mouses, you are still going to have some lag. If you don't notice ANY, in my book you need an eye transplant.
Outrigger said:I guess I need an eye transplant because I noticed no lag whatsoever playing games like GRAW, and BF2 using mice such as the g5, g7, and razor. best lcd I have used.
also, a lot of the negative posts are by people who have never even seen one in person, they're just reiterating a couple of bad experiences. I can only speak from my own experience because I have actually USED one.
Pros: Good color reproduction, good black levels, good viewing angles, extraordinary response time. I've hammered this with every high speed game you can think of and I have yet to see any ghosting or moti...
on blur ... better than some CRT's I have tested (Seriously)
Cons: (1) VERY slight input lag. Perhaps I was just used to using the same G400 monitor for 6 years. This was easily corrected by increasing the pointer speed in the control panel (tested with a MS LaserM... More »
ouse 6000 at 1000dpi.) Far less than other 24" LCD's (2) No built in 4:3 scaling (black bars on the sides). Not a problem with Nvidia drivers. ATI can only do centered timings (black bars all the way around.)
Other Thoughts: After trying a wide array of LCD monitors (including the 244t and 2407FPW which I mention since they are also 24" WS LCD's) I have finally found something worth moving off my Triniton CRT for ... and I'm a very picky person. If you are looking for an all around good LCD this is it. Keep in mind you will need a powerful graphics setup to run the latest titles at 1900x1200 with AA/AF/settings maxxed, etc.
I just looked at the samsung site,
http://www.samsung.com/uk/products/monitors/lcd/largeformatdesktop/ls2...bbsedc.
I wish Id went there to begin with, the spec page for the 244T states '400 brightness' and '10ms grey to grey' as opposed to the 2407's( 450 and 6ms)
This gives the Samsung a much lower spec, than that flouted on review/shoppping sites(500 and 6ms), in fact I dont remember seeing these specs(400 and 10ms) on any third-party sites,
Do you think its possible they changed the spec since the release?
PS something odd is going on:
Here is the 244T spec page on the global site
Here is the 244T spec page on the UK site
http://www.samsung.com/Products/Monitor/LCD_Multi_Function/LS24BRBABXA...sp?page
The specs dont match, does that mean im getting the crappy UK one?
Quote:
"Incase you didn't realise, the Dell uses exactly the same Samsung flat panel as the Samsung, so any difference in specs is down to marketing."
After everything Iv read on this subject I coudnt get my head round this, so I called Samsung UK(twice), who confirmed that the UK/US are different, and its because of the regional power supply differences(Aye rite!), they said that they coudnt confirm that the UK/US use the same panel, or even tell me the panel number of the UK version, WOW WTF?
Here is a link showing a silver with the good spec, so its not about black or silver:
http://www.samsung.com/Products/Monitor/LCD_Multi_Function/LS24BRBASXA...sp?page
So we pay twice as much for an inferior version, than the US???
The Samsung should arrive sometime today, but Im already thinking of sending it back, and going with the Dell 2407, It's a bit cheaper and better spec...wot did I really say that?
'My padded cell awaits'
tuk said:See the full thread here:
I wonder if the people experiencing the input lag have this inferior version of the Samsung 244T,
Do you see contradiction here?Bowen said:Both use the same panel vs. it's pixel pitch is slightly better
Why do people do this?Bowen said:Ya know on this input lag issue, I do think it has to do with allot of factors and I think the #1 factor is their video card, followed by out of date video card drivers, followed by not enough RAM and then round that out with a generic mouse. I bet though, that the video card and or the video card and bad drivers are the main cause.
I'm going to get the 244T or the BenQ FP241W. Both use the same panel, but the BenQ has a few more inputs on it, which doesn't matter to me.
Have you ever used a large monitor with a slow video card? It doesn't add lag at all. I don't know why people keep assuming the problem is the video card not being able to keep up.Bowen said:So I'd bet that the people experiencing input lag have slow video cards that can't keep up anyway, in which case is no fault of the monitor anyway.
