I basically need help with everything that's listed in the thread title as I don't have extensive knowledge with using any of these programs and what settings to adjust etc. I did a search on the forums and found some older posts on what to adjust etc. Problem was after reading the posts and then trying to mimic the settings I wasn't finding some of the codes that I have installed to be listed.
So I thought I'd ask for help in a new post for what I need to do/upgrade and what settings could I run with my particular setup. I have the system listed in my sig below and I think I should have more than enough processing power to run and do what I want, or at least I think I do?
I have Zoom Player Professional version 4.51, FFDShow[rev.2543],NVIDIA.Pure Video Decoder V. 1.02.233, WMP v. 10.00.00.4306 (if this matters). I'm also using the KLCodec 277FBeta1version of codec files. I also have Power Dvd and another player or two in some software that I don't have installed at this time but can install if needed.
When I bring up the zoom player and try to play I file I get some errors of not finding certain things so I'm sure this is just settings. When I try to find the codec for the NV Purevideo Decoder in the zoom player settings it doesn't show up under the video decoder listing.
Another question I have is, when you install the NVidia purevideo decoder does it show up in the start/programs menu in windows or only in players with some sort of shortcut to access the menu for settings adjust??
Finally, here's what I want to be able to do with the player and what I'm looking for out of the codecs etc. I would like to be able to view my dvd's via Zoom Player or WMP with upconversion to experience the incredible picture quality difference that I've read about and seen in screenshots. I would also like to set up the ffdshow or nvpv decoder to upconvert standard SD signals as well and improve HD if that is possible.
I have an AVerMedia TVHD MCE A180 and a ATI Theater 550 PRO TV Tuner, PCI Express for SD on the way, as well as another 250g hd for additional storage space.
I would like to run my comcast sd signal through the ATI card if possible and then upconvert the signal to the best quality possible.
I wanted a quam tuner to take advantage of the comcast hd channels that aren't flagged but couldn't seem to locate a pci express card with that capability (though I could've missed one).
I also need help with the audio settings as well to get the best sound quality for my setup. Right now I have an adaptor out my Audigy 2 ZS pro going into my receiver via rca cables (analog ) but at least I get Dolby Prologic 2 EX or 5.1 Stereo so it's not all bad .
I'm going to order Sound Blaster Home Theater Cable or Sound Blaster Digital I/O Module to connect to my receiver for 5.1/6.1/7.1 surround.
According to the listing of what sound cards work with the digital I/O module, mine will not work with it. I find this strange b/c an Audigy 2 Value and an Audigy Value/Se will work with it but my Audigy 2 Pro will not?? I have a digital audio out on my sound card where this unit is supposed to connect so I don't see why it won't work, but if someone know's if it will or why it won't please let me know as I'm going to order one this week.
I'm going to be using my pc for hd recording and viewing for now as well as some sd recording viewing as well. This whole pc will soon be in converted to an HTPC case with Vista and a new Core 2 or AM2 system will be my 2nd HTPC/Gaming rig on a new, not yet decided 1080p 56" or larger tv or possibly a projector setup. Though that's 6months down the road so for now I'll be living with HD on my Sony HD PC monitor.
Any comments (positive) or help is muchly appreciated as I have no experience with HTPC's yet and have just decided to start toying around with all the cool possibilities it will offer.
*Sorry about the size of the post with all the info and questions, but I've learned to give as much info as possible to make it easier on the people trying to help you.* Thanks Again!!!!!
