coo-coo-clocker
- Sep 6, 2007
Is there a thread or guide somewhere that is similar to Bill Parrish's excellent P965 guide for the striker extreme or similar mobo?
Interesting. I saw the same behavior, but I've done a bit of investigation and here's what I've found. Upon resetting the CMOS or installing the BIOS 1305, the voltage and fan instrumentation are all there and working fine. When I run CPU-Z (v1.41), it has some kind of nasty interaction, because after running CPU-Z, the voltage and fan instrumentation in the BIOS is blown away. Resetting the CMOS will restore it back to normal, but you just have to re-configure all your BIOS settings. I don't know enough about the BIOS or the CPU-Z program yet to know where the "bug" resides. My next test will be to see if I can load the BIOS profile I have saved off and see if that restores the voltage and fan readings.Best bios to use is the 1303, I had good results with the new 1305 but had zero fan control and lost my voltage reading from the NB, SB CPU VTT...so I went back to 1303
