I am at my wits end on this issue. In early Nov.'07 I built a system with the Abit IN9-32X Max 680i motherboard. Updated the BIOS to version 13, right after install, but didn't know enough about saving the BIOS or clearing the CMOS and saving, after any changes to the RAM configuration. Blew out a 1 gig. Crucial Ballistix DIMM, had it replaced, but bought Kingston HyperX 4x1gig SLI Ready, same as previous Crucial. I felt my problems with the system were from this issue. Had to do new installs of all drivers and some software and the system seemed to be working right for several days. I bought a second video card XFX GeForce 8800GTS 640 Mb. exactly matching the other card, same model/part number for SLI use, but in Mid Nov. my system fell apart after playing Crysis for several hours without any problems, the first time I was able to do so, on this system. I closed the game and did a shut down of XP Pro and it went to a Blue Screen of Death, BSOD, and the restart got to my desktop and another BSOD, the second restart completed, but error windows were popping up. The next day I worked some hours, doing new installs for various drivers and things seemed to be working right, but when I went to print something, I found the print spooling service of Windows wasn't working and I had no access to any of my printers or fax services. This prompted me to buy a new motherboard, but the cost of the second video card pushed me to the new 780i and I then bought the XFX one, just reviewed here. I did a new fresh install of XP Pro and all my software, just after the 780i was installed. For many days all seemed to work great. I played DarkStar One for three days, several hours a day. The second day there were problems with crashing, but Chkdsk ran during the restart of a system crash and found errors. I ran Chkdsk on all my partitions again, with no errors found. I used the system the next day and things seemed fine and played DarkStar again, but after an hour or two, it started crashing and a system restart had a BSOD and the desktop after had many error pop up windows just like the 680i experience. I don't overclock, other than boosting DDR, RAM, voltage to 2.2 volts and using the SLI Memory Ready option in the BIOS. It is ridiculous to think playing a PC game should corrupt your system files or you have to repair or do a new OS install every couple of weeks. Why don't these 600 and 700 NVidia motherboards work like most other boards? I am thinking, a $100. or under board is less trouble and more reliable. Any help, suggestions will be appreciated.
