jfnirvana292
- Apr 9, 2002
So I took the plunge and bought the HP 2133 mini-note laptop. Let me tell you, this thing is the coolest little laptop i've ever had.
Almost immediately after holding it I could tell it is well built. Its constructed of metal, and has a nice heft to it--not chinsey plastic. The keyboard is great--just like typing on a regular laptop. The screen is super high resolution, especially for its size. 8.9 inch screen and a 1280 x 768 resolution. Just fantastic.
As for performance, this category is the one I was most worried about. I've heard some talk that the VIA processor was crappy. Well, after running vista on it, ive come to the conclusion that it's alright. Not exactly speedy, but not sluggish. I did turn off the "performance hog" settings such as all the graphical frills and it runs a bit zippier. I'd say for what im doing (web browsing, word processing, chatting etc) this is just perfect.
I picked up a Targus 10" portable DVD player case for it--its almost a perfect fit, just a little too tall for the laptop. Thats ok though, since it has a strap to keep it in their tight.
All in all, im impressed. This is one of the nicest machines i've had in terms of quality, and usability for a small laptop. I'd rate it a 9/10.
Specs:
1.2ghz VIA processor
120gb hdd
1gb ram
Wireless
Ethernet
2 USB ports
8.9" 1280 x 768
All metal casing
WIndows Vista
Pictures:
Specs:
120gb hdd
1gb ram
Wireless
Ethernet
2 USB ports
8.9" 1280 x 768
All metal casing
WIndows Vista
Pictures:
