Hi guys, I just received the BenQ V2400W courtesy of Kyle Bennett of [H]ardOCP and the BenQ America Corp. I'll be reviewing the BenQ V2400W 24 in. LCD Monitor as part of the "BenQ V2400W User Reviews @ [H]Forum". First of all, I'll start off with a little introduction of the monitor:
1. BenQ V2400W
Package arrived in pretty good condition.
The retail box containing the monitor is well protected by a layer of packaging noodle.
Top layer packaging noodle removed reveals the retail box.
Retail box removed from the shipment package, it's in mint condition.
Some product information on the retail box.
Unit removal instructions.
Opening of the retail box. The unit is well protected.
We can see the power cable, vga cable, quickstart guide, and a CD with the manual, .icm, .inf, .cat files, and a copy of Adobe Acrobat Reader.
The unit rests firmly inside the retail box.
Everything in the retail box removed.
Frontal View. The glossy bezel is protected by strips of plastic film.
The monitor looks very modern, I like the overall feel to it, and the off centered base piece does not affect the balance of the unit at all.
Also, as you can see it's a matte screen surface.
The buttons doesn't actually click like the way it looks, they're touch sensitive buttons.
Side view, with a card for size reference.
The audio output port on the left side of the monitor with a standard headphone .35mm jack. I'm guessing it transmits the sound from HDMI.
From right to left, D-Sub, HDMI, DVI.
The power port is further down left, you can sort of see it?
The glossy bezel extends all the way to the back.
Go ahead! make out the numbers on the card!
More monitor unit information.
The V2400W itself is really thin indeed!
A shot at the base.
Unfortunately the base only pivots up and down, it doesn't twist or move up and down.
Also, the base is actually made of plastic, and not aluminum like it seems.
Alternative mounting options also seems to be a no go.
1. BenQ V2400W
-Initial Overview of general specs and info
Screen Size: 24.0" Wide Screen
Bezel Color: Glossy Black
Screen Surface: Matte
Native Resolution: 1920x1200 (WUXGA)
Native Aspect Ratio: 16:10
Pixel Pitch: 0.27 mm
Brightness: 250 cd/㎡
Contrast Ratio: 1000:1 (Typ.) 4000:1 (DCR)
Typical Response Time: 5ms
Overdrive Response Time: 2ms(GTG) [AMA - Advanced Motion Accelerator]
Display Area: 518.5x324 (mm)
Display Color: 16.7 million colors
Viewing Angle: 160 / 160 degrees
Input Signals: D-sub / DVI-D/ HDMI/ Earphone
Horizontal Frequency: 31~83 (KHz)
Vertical Frequency: 55~76 (Hz)
Video Bandwidth: 25~135 (MHz)
Color Temperature: Reddish / sRGB / Bluish / User mode
Power Consumption: 55W (max)
Power Supply: Built-in
Adjustments Tilt: (down/ up ONLY) -5 / 20 degrees
Dimensions: 563.8x369.4x191.7 (HxWxD mm)
Weight: 6.7 KG
Accessories (Standard): VGA cable, Power cable
Vista Certification: Premium
Weight: 6.7 KG
-Packing Evaluation and Unboxing pictures
A shot at the base.
-Initial Inspection for damage or anomalies
Fortunately, there doesn't seem to be any physical damage to the unit, as the monitor is pretty well packaged. There also doesn't seem to be any dead/stuck pixels after a couple quick scans through the main display . All in all, it looks like the monitor is in great physical conditions.
-Peripheral check
1x VGA Cable ~6ft.
1x Power Cable ~6ft.
1x BenQ V2400W LCD Monitor Quick Start Guide
1x CD contains User Manual, .icm, .inf, .cat files, Adobe Acrobat Reader
-Note panel built date and location
Built Location: China
Built Date: April 2008
