UPS brought me a small brown box this morning. It contained within it 2 WD 1500 HLFS VelociRaptors! I bought them a couple days ago from 'da Egg. (Aside: dang it! they're $10 cheaper each than when I bought them like 4 days ago... )
Aren't they sharp?
Raptor, Raptor, Raptor! One of them is a touch faster than the other two...
And, a picture of the 2.5" -> 3.5" form factor conversion for those interested in noting its newfound backplane compatibility.
One other note: both drives carry the suffix 01G6U0
Ok, now to set the stage... I have just installed Home Premium Vista x64 on 1 of the 2 VRaptor 150s. I will run all (single drive) benchmarks on the empty VRaptor.
After the clean install of x64, I installed my ICH9R system bus drivers from Intel, my SoundMAX drivers, also from Asus, my Marvell Yukon Eth drivers, NV 175.19 and (in a moment) Service Pack 1.
Ok, in the spirit of getting and giving information, if any of you would like me to run benchmarks other than the ones I'm going to run (because these 3 are basically mandatory), list 'em out (with a trust-worthy download link) and I'll try to give them a shot.
For your benchmarking pleasure, I'll offer the presumptory HDTach, HDTune and the newest Sandra. I'll try to run them on both a single drive, and the RAID 0 I'm going to setup once my single drive testing is complete. Oh, almost forgot IOMeter.
Also, if you'd like some other info on my system, other than the signature, or my installed apps details, shout it out.
Ok, first: Vista install took <12 minutes. Stopwatch started after I defined the disk and it began installing, up to the time where it requested my timezone information.
While I'm waiting on SP1 to download so I can install it, and to whet your appetite (and to allow pre- and post-SP1 comparisons), I'll start you off with some benchies.
*saving my work by starting the thread*
Ok, 32MB Long Bench on HD Tach...
32kb block, slider bias fully to 'accurate' HDTune...
Sandra, disk test, all options enabled, queue depth=4...
Aren't they sharp?
