5ms hips 24 incher relaesed Philips 240PW9EB
Sathsayin
http://lcd24-7.info/Monitor/Philips/240PW9EB/Default.aspx has usb ports
Class
Display LM240WU4
Size 24"
Diagonal 611.322 mm
Active Area 518.4×324.0 mm
Resolution 1920×1200
Technology H-IPS
Response (rise+fall)
Response (gray-to-gray) 5 ms
Input Lag
Backlight
Contrast 1,000:1
Dynamic Contrast 3,000:1
Brightness 400 cd/m2
Pixel Pitch 0.27 mm
Color Depth 16.7 mil.
Gamma Correction (LUT)
Color Gamut 102 % NTSC
Viewing Angles (C/R 10:1) 178/178°
Viewing Angles (C/R 5:1)
Cabinet Color
Pivot Yes
Swivel ±45°
Tilt -5/+20°
Height Adjustment 130 mm
Picture in Picture No
HDCP
HDMI No
DVI-D Yes
D-Sub Yes
Composite No
Component No
S-Video No
DisplayPort No
D-Terminal No
HD/SD SDI No
USB Yes
Speakers No
Audio Input (Jack ø3.5 mm) No
Audio Output (Jack ø3.5 mm) No
Horizontal Frequency 24-94 kHz
Vertical Frequency 48-85 Hz
Power Supply Internal
Power (Max)
Power (Typical) 45W
Power (Idle) <1W
Dimensions (W×H×D) 559×435×220 mm
Dimensions (Base) 559×381×75 mm
Weight 8.1 kg
VESA 100×100 mm
Kensington Lock Yes
TCO TCO'03
Windows Vista Logo Certified for Windows Vista
Warranty
Pixel Defects (ISO 13406-2)
you guys think this will replace your nec 20wgx2's
uses the same panel as the lp2475
but with a 5 ms repsonse time
Yeah, I've got the right lighting conditions in my room so that the reflection doesn't annoy me at all. I owned a TN matte screen before my 20WMGX2 and the colors seemed incredibly dull on it. Maybe it was the finish or panel type, dunno... but I'm trying to avoid both TNs and matte screens now.
I prefer glossy myself and i did the same thing ironicly. I like what it does to the colors makes them deeper(?). I would like to get ahold of a 20wmgx2 or 20wmgx2 myself but i finally setteled with the l227wtg-pf it was next in line i'm married so can't afford anything better. surprisingly this panel isn't that dull once h-ips hits 3 ms i'll spend a grand are more on it but untill then i'll wait I like high refresh rates and i play at higher than 60 hz and i like to overdrive the pixels abit so this is what works for me. I was looking at the hazro 24 inch but it isn't in the us. Don't wont to order form over the pond because of backlight issues are if there is a problem even worse so.... Wouldn't want to sell yours would ya.... ??? lol
It seems it may be another non-North American release, of yet another well priced IPS unit. I have only found it for sale in Asia at the moment.
It seems to use the same display as the problem ridden HP LP2475W. Am I safe to assume it'll have the same problems?
Nope. Different internals may provide different results. The uniformity and other panel related issues may still be present though.
