[H]ard|Forum
Go Back   [H]ard|Forum > [H]ard|Ware > Data Storage Systems
Reply
Thread Tools Search this Thread
  #1
Old 08-10-2009, 05:06 PM
[LYL]Homer 2[H]4U, 5.7 Years
[LYL]Homer is offline
GP/low-power drive wattages & specs for each manuf
Some of you may have seen me post about drive wattages, here's a bunch of info that I've just been compiling. Since I was looking I figured I'd copy it and make it available for everyone as it wasn't always easy to find every bit of info.
I've tried to list the series, speed, buffer, and warranty in the notes since those are other important factors. All are SATA versions - some lines had SAS or IDE - but I figured this was aimed mostly at WHS users. I've also included non-LP/GP and enterprise-class drives at the end of each manufacturer's listing under 'Select drives for comparison'.
Let me know if you find any errors. If this seems useful to everyone else I'll end up maintaining it.
Code:
Western Digital 3.5" drives
model          size  read/write  idle   notes
WD2002FYPS       2tb    6.8      3.7    WD RE4-GP, 5400rpm, 64mb, 5yr 1
WD20EARS         2tb    6.0      3.7    WD Green, 5400rpm, 64mb, 3yr
WD20EADS         2tb    6.0      3.7    WD Green, 5400rpm, 32mb, 3yr 1 2
WD20EVDS         2tb    5.9      4.9    WD AV-GP, 5400rpm, 32mb, 3yr
WD15EARS       1.5tb    6.0      3.7    WD Green, 5400rpm, 64mb, 3yr
WD15EADS       1.5tb    6.0      3.7    WD Green, 5400rpm, 32mb, 3yr
WD15EVDS       1.5tb    5.9      4.9    WD AV-GP, 5400rpm, 32mb, 3yr
WD10EARS         1tb    5.4      5.4    WD Green, 5400rpm, 64mb, 3yr
WD10EADS         1tb    5.4      2.8    WD Green, 5400rpm, 32mb, 3yr 1 2
WD10EVDS         1tb    4.9      4.2    WD AV-GP, 5400rpm, 32mb, 3yr
WD10EACS         1tb    5.4      2.8    WD Green, 5400rpm, 16mb, 3yr 1
WD10EAVS         1tb    5.4      2.8    WD Green, 5400rpm, 8mb, 3yr
WD10EVVS         1tb    5.4      2.8    WD AV-GP, 5400rpm, 8mb, 3yr
WD1000FYPS       1tb    7.4      4.0    WD RE2-GP, 5400rpm, 16mb, 5yr 1
WD7500AADS     750gb    5.4      2.8    WD Green, 5400rpm, 32mb, 3yr
WD7500AVDS     750gb    4.9      4.2    WD AV-GP 5400rpm, 32mb, 3yr
WD7500AACS     750gb    5.4      2.8    WD Green, 5400rpm, 16mb, 3yr
WD7500AAVS     750gb    5.4      2.8    WD Green, 5400rpm, 8mb, 3yr
WD7500AVVS     750gb    4.9      4.2    WD AV-GP, 5400rpm, 8mb, 3yr
WD6400AACS     640gb    5.4      2.5    WD Green, 5400rpm, 16mb, 3yr
WD6400AAVS     640gb    5.4      2.5    WD Green, 5400rpm, 8mb, 3yr
WD5000AADS     500gb    5.4      2.5    WD Green, 5400rpm, 32mb, 3yr
WD5000AACS     500gb    5.4      2.5    WD Green, 5400rpm, 16mb, 3yr
WD5000AAVS     500gb    5.4      2.5    WD Green, 5400rpm, 8mb, 3yr
Code:
Select drives for comparison:
WD2003FYYS       2tb   10.7      8.2    WD RE4, 7200rpm, 64mb, 5yr
WD2001FASS       2tb   10.7      8.2    WD Black, 7200rpm, 64mb, 5yr 1
WD1001FALS       1tb    8.4      7.8    WD Black, 7200rpm, 32mb, 5yr 1 2
WD6401AALS     640gb    8.3      7.7    WD Black, 7200rpm, 32mb, 5yr
WD7500AAKS     750gb   8.77      8.4    WD Blue, 7200rpm, 16mb, 3yr
WD6400AAKS     640gb    8.3      7.7    WD Blue, 7200rpm, 16mb, 3yr 1
WD3000GLFS     300gb   6.08     4.53    VelociRaptor, 10k rpm, 16mb, 5yr
WD1002FBYS       1tb    8.4      7.8    WD RE3, 7200rpm, 32mb, 5yr
WD7500AYYS     750gb   11.5      8.5    WD RE2, 7200rpm, 16mb, 5yr
Code:
Western Digital 2.5" drives
WD10TEVT      1tb    2.5     0.85    Scorpio Blue, 5200rpm, 8mb, 3yr, 12.5mm
WD7500KEVT  750gb    2.5     0.85    Scorpio Blue, 5200rpm, 8mb, 3yr, 12.5mm
WD6400BEVT  640gb    2.5     0.85    Scorpio Blue, 5400rpm, 8mb, 3yr, 9.5mm
WD5000BEVT  500gb    2.5     0.85    Scorpio Blue, 5400rpm, 8mb, 3yr, 9.5mm
Code:
Seagate
ST32000542AS     2tb    6.8      5.5    Barracuda LP, 5900rpm, 32mb, 3yr 1 2
ST31500541AS   1.5tb    6.8      5.5    Barracuda LP, 5900rpm, 32mb, 3yr
ST31000520AS     1tb    5.7      3.7    Barracuda LP, 5900rpm, 32mb, 3yr
ST3500412AS    500gb    5.0      3.4    Barracuda LP, 5900rpm, 16mb, 3yr
ST32000641AS     2tb   9.23     6.39    Barracuda XT 6Gb/s, 64mb, 5yr 1
ST31000528AS     1tb    9.4      5.0    Barracuda 7200.12, 32mb, 3yr 1
ST3750528AS    750gb    9.4      5.0    Barracuda 7200.12, 32mb, 3yr
ST35000418AS   500gb    8.0      5.0    Barracuda 7200.12, 16mb, 3yr
ST31500341AS   1.5tb    8.0      5.0    Barracuda 7200.11, 32mb, 5yr 1 2
ST31000340NS     1tb   11.6      8.0    ES.2, 7200rpm, 32mb, 5yr 1 1
Code:
Maxtor
STM31000528AS    1tb   6.57      5.4    DiamondMax 23, 7200rpm, 32mb, 3yr
STM3750528AS   750gb   6.57      5.4    DiamondMax 23, 7200rpm, 32mb, 3yr
Code:
Samsung
HD203WI          2tb    ...      ...    EcoGreen F3, 3yr
xxxxxxx        1.5tb    ...      ...    EcoGreen F3, 3yr
HD154UI        1.5tb    6.3      5.1    EcoGreen F2, 5400rpm, 32mb, 3yr 1
HD153UI        1.5tb    6.3      5.1    EcoGreen F2, 5400rpm, 16mb, 3yr
HD103SI          1tb    5.8      4.6    EcoGreen F2, 5400rpm, 32mb, 3yr 1
HD102SI          1tb    5.8      4.6    EcoGreen F2, 5400rpm, 16mb, 3yr
HA103UI          1tb    6.2      5.0    EcoGreen F1 CE, 5400rpm, 32mb, 3yr
HD502HI        500gb    5.1      3.9    EcoGreen F2, 5400rpm, 16mb, 3yr
HD502HJ        500gb    6.5      5.0    Spinpoint F3, 7200rpm, 16mb, 3yr
HD103UJ          1tb    8.4      6.7    Spinpoint F1, 7200rpm, 32mb, 3yr 1
HE103UJ          1tb    7.9      7.7    Spinpoint F1 RAID, 7200rpm, 32mb, 5yr 1
Note: Samsung OEM drives carry 30 day warranty.
Code:
Hitachi
HDS722020ALA330  2tb    ?.?      7.5    Deskstar 7K2000, 7200rpm, 32mb, 3yr
HDS721010CLA332  1tb    ?.?      4.4    Deskstar 7K1000.C, 7200rpm, 32mb, 3yr
HDE721010SLA330  1tb    ?.?      5.4    Deskstar E7K1000, 7200rpm, 32mb, 5yr
A7K1000          1tb   13.6      9.0    Ultrastar, 7200rpm, 32mb, 5yr 1
Hitachi had the most masked information hidden in white papers. Their drives use a "normal idle", "unload idle", and "low idle" which you can read about here. Unfortunately they don't seem to give read/write power specs anywhere. I've also noted the Deskstar drives as 7200rpm but it is unclear if and how much the drives spin down in their various modes.
Related articles on power consumption:
WD Advanced Format (EARS series)
Anandtech - The Cost of Running Your PC
XBit article
__________________
Low power/GP drives: http://www.hardforum.com/showthread.php?t=1442303
  #2
Old 08-13-2009, 09:57 AM
Boomslang Limp Gawd, 2.8 Years
Boomslang is online now
Nobody seemed to give you any props for this, but I found it quite helpful and will probably be referring to it in the future. Thanks for putting the time in.
  #3
Old 08-13-2009, 03:12 PM
XS Janus Limp Gawd, 1.8 Years
XS Janus is offline
WOW how did I miss this!
Thanks for this!
It will come in handy more than once.
Thanks for the all the hard work!
  #4
Old 08-13-2009, 03:40 PM
Thanks for the feedback.
For the "Select drives for comparison" I just chose a few more popular models since I didn't want to research all of hard drive history. But, going forward, as new GP/LP and non-GP/LP drives come out I'll add them.
If anyone finds a new drive to add please reply with a link and I'll update the first post.
__________________
  #5
Old 08-13-2009, 03:47 PM
extide Gawd, 1.1 Years
extide is offline
BTW, on the WD site I have read once that the green drives each use a "Unique non-variable RPM optimized to the drive's characteristics"
EDIT: Also this line:
WD6401AALS 1tb 8.3 7.7 WD Black, 7200rpm, 32mb, 5yr
should probably be this:
__________________
MainBox: Q9550@4Ghz, 8GB DDR2, Asus P5Q-E, Win 7 x64 RTM, Scythe Mugen2, 128GB G.Skill Falcon, 2x ATI4850 512MB Crossfire, Auzentech X-Fi Forte, Grado Labs SR-80, Twin 23" 1080P LCD's
Box2: E6600, 4GB DDR800, Asus Maximus II Formula, Win 7 x64 RTM, Scythe Mugen2, 500GB Seagate ES.2, ATI x1950Pro 512MB
HomeServer: Core 2 Duo E6600, 2GB DDR2, Server 2003, Intel S3000AH ServerBoard, Intel Fiber GigE, 80GB WD for OS, 4x500GB WD in Raid 5 on Promise SuperTrak S150 SX4 w/512MB PC133 in 66Mhz PCI, 2x750GB Seagate in Raid 0 on onboard Raid.
Fun: 04 Volkswagen GTI VR6Turbo (GT35R, 630cc, Unitronic, and more)
http://sourceforge.net/projects/imagizer2/
  #6
Old 08-13-2009, 03:54 PM
Yeah, I read several sources on WD drive speeds as to whether they were fixed in speed or actually variable. If you see something definitive post a link.
Thanks for the 1tb catch, fixed.
__________________
  #7
Old 08-19-2009, 08:33 AM
EnderW [H]ardForum Junkie, 6.4 Years
EnderW is offline
very nice, this should be a sticky
__________________
  #8
Old 08-19-2009, 09:24 AM
Yakyb Limp Gawd, 1.9 Years
Yakyb is offline
thanks for this makes me wonder whether to buy the WD greens or the samsung
__________________
Gaming Box:: q6600 @3.0 :: 9800gtx :: Abit IP35 :: 4gb :: 1.4TB :: akasa eclipse :: Win7
Development:: PhenomII 955BE @3.2 :: 4200 :: asus M4A785 M Evo :: 1.25TB ::Win7
Media Centre :: q6600 @3.0 :: x1950pro :: asus p35 epu :: 8gb :: 320 GB :: Lc17B :: Win7
server:: I7 860 :: p55 gd65 :: 3450 :: 8 TB :: 8gb :: Rebel 12 :: server 2008 R2
  #10
Old 08-19-2009, 09:37 AM
epimetheus Gawd, 5.6 Years
epimetheus is offline
I just picked up 3 of the Samsung 1.5TB from the Egg for $99 a piece before %6 Bing CB. Fingers crossed that the Savage Baggage Handlers in the warehouse aren't to rough on them. I'm doing a Mini-ITX/Atom/WHS build with the Chenbro ES34069 case.
  #11
Old 08-19-2009, 10:01 AM
brycejones 2[H]4U, 8.0 Years
brycejones is offline
Thanks for pulling this info together, it explains why my Hitachi drives run 7C hotter than my samsung and WD EACS drives.
__________________
Heatware 116-0-0 under bryceejones
Some number of ghz folding for the [H]
Put that OC'd CPU to some good use. Join the [H]orde.
www.hardfolding.com & visit us in the Distributed Computing forum.
  #12
Old 08-19-2009, 11:29 AM
Thanks Old Hippie, even though it is based on some assumptions it seems somewhat conclusive so I changed the rpm for the Greens.
__________________
  #13
Old 08-19-2009, 12:54 PM
L1Trauma [H]Lite, 7.2 Years
L1Trauma is offline
Great thread.
  #14
Old 08-19-2009, 04:46 PM
SockMan! [H]ard|Gawd, 5.5 Years
SockMan! is offline
Frequency analysis also supports the notion that WD Green Power drives are 5400RPM. It's an older article, but GP drives probably haven't changed rotational speed since then - at least not that I'm aware of and certainly not up to 7200 RPM.
__________________
Did it blow up yet?
  #15
Old 08-19-2009, 05:01 PM
demechman [H]Lite, 4.7 Years
demechman is offline
I have 4 of the 2tb models and the consumption looks correct. Great job on collecting the info
  #16
Old 08-20-2009, 08:53 AM
KevinG Limp Gawd, 6.6 Years
KevinG is online now
Wow! This thing must sound like a freakin' jet airplane!
"WD5000AACS 500gb 5.4 2.5 WD Green, 54000rpm, 16mb, 3yr"
  #17
Old 08-20-2009, 09:23 AM
axan [H]ard|Gawd, 4.3 Years
axan is offline
thanx for the work [LYL]Homer, pretty useful info.
__________________
Asus MIIF q9550 GSkill 16GB (4x4gb) | Visiontek 4870x2 | Asus Xonar DX | Samsung LN40A650 2x 2443BWX 2x 943BX | OCZ Vertex 60gb 2x Vertex 120 raid0 | CM Cosmos S Corsair 1000hx Windows 7 x64
Tera File Server| Asus DSBF-DE| Xeon e5405 | 4GB ECC RAM| Areca 1280-ML | 20 x 1TB Seagate ST31000340AS | Norco 4020 | corsair 1000hx | Gentoo x64 OS - http://www.hardforum.com/showthread.php?t=1341257
Alters - VMware vSphere Server | Asus DSBF-DE| 2x Xeon e5405 | 16GB ECC RAM | Adaptec 5805 | 8 x Hitachi 36.7GB 15K SAS | supermicro 825TQ | worklog - http://www.hardforum.com/showthread.php?t=1360511
  #18
Old 08-20-2009, 10:14 AM
Old Hippie 2[H]4U, 4.3 Years
Old Hippie is offline
Quote:
I'll second that emotion! ( This is the spot where a great big thumbs-up would be placed if there was one)
__________________
Old Hippie,
Rick
  #19
Old 08-20-2009, 11:49 AM
fixt
__________________
  #20
Old 08-24-2009, 10:04 AM
can we get this stickied?
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Valid XHTML 1.0 Transitional
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright 2000 - 2009 KB Networks, Inc.
