craigslist or ebay.. but honestly without a budget it would be hard to recommend anything..
Haven't ever seen a consumer edition triple monitor arm that can hold jumbo sized 28" monitors. I'm sure they exist for slightly more industrial applications but then it's almost guaranteed to cost an arm and a leg.
Any chance on settling upon 3 separate arms? Believe it or not you might have less visible metal to stare at going that route, a true triple arm for 28" LCD's could have pipes sticking out everywhere, or have problems with flexing or tilt.
Unfortunately i don't know which websites sell the more industrial stuff, might take some creative google search terms, or another forum member to point one out.
Seems nice but I feel it's somewhat lacking. It also states "Max 33Lbs, 10~23inch" which technically rules my LCD's out. I'm sure it could work, just makes me reconsider just jumping on it.
Edit: I would also really like to have one that is made for three large LCD's. The one above is for four smaller LCD's which would make the pipes stick up real high for no reason in my particular situation.
Edit_2: Something like this but for larger LCD's.
[/URL]
I'd say 3 ergotron single display arms is your best bet. A mount for 2 displays that big is probably going to be a bit unstable.
He'd probably link you models with the wrong Vesa bracket size. It's a pain but you'll have to figure out what Vesa standard your monitor uses then head over to the ergotron website to see what they have to offer. When you find the right arm you then plug that model number into google shopping to see who sells them for less. Remember Vesa bracket size is only one aspect to look out for, you also have to make sure the mount will hold your monitor's weight.Not trying to look lazy but can you point that one out so I know what one you're referring to?
And thanks everyone for the help so far.
Thanks
For some reason Newegg doesn't list the Vesa size, i have a feeling it's one of the more common sizes but i'd be hesitant to assume (i've messed up once already).Here's my LCD's. How can I tell what arm I need?
http://www.newegg.com/Product/Product.aspx?Item=N82E16824254026&cm_re=hanns_g-_-24-254-026-_-Product
I have updated my monitor setup just a few days ago maybe you guys are interested.
http://dbmethod.com/popular/ultimate-arm-lcd-mount/
Thankfully newegg lists the Hanns-G contact information, maybe email a hanns-g rep and ask them what Vesa mount size your monitor uses:
* Website: http://www.hannsg.com/us/
* Support Phone Number: 888-842-6674
* Support Email: [email protected]
* Support Website: http://usservice.hannsg.net/
* View other products from Hanns-G
i'm a current Hanns-G 28" owner myself who is heavily considering an Eyefinity setup...
could you PLEASE post pics of your triple Hanns-G setup - with or without arms?
Thanks.
