Features
-- Supports Socket-370 based CPU ( CeleronTM/ Pentium® III ) up to 133MHz FSB
-- Intel 815E Chipset
-- Built-in VGA function with share memoryarchitecture
-- Built-in AC'97 audio function
-- Built-in 10/100Mbps Ethernet with RJ-45connector
-- One CF+ Type II socket on board
Specifications
-- CPU : Supports Socket-370based CPU ( CeleronTM / Pentium® III ) up to133MHz FSB
-- System Memory : One 144-pinSO-DIMM socket up to 256MB SDRAM
-- System Chipset :Intel® 815E Chipset
-- BIOS : Award PnP FlashBIOS
-- Video Controller:
-- --> Built-in Intel® 815E chipset with sharememory architecture
-- --> Max. Resolution : 1600 x 1280 (8-bit colors )
-- --> Connectors : DB-15 standard VGAconnector
-- Super I/O :
-- --> 2 xRS-232 ports
-- --> 1 x parallel port ( support SPP/EPP/ECPmode )
-- --> IrDA
-- USB Ports : One port bypin-header, meet USB ver.1 standard
-- Ethernet : Built-in systemchipset with RJ-45 connector
-- Aduio : Built-in systemchipset with AC'97 codec
-- IDE : One port by 44-pinpin-header; supports Ultra DMA66/100 mode
-- FDD : One port
-- Software Programmable WatchdogTimer
-- SSD : One CF+ Type IIsocket ( Support IBM Microdrive compact size HDD )
-- Optional Extension FunctionBoard : TV Out, 8-bit Digital I/O, RS 232/422/485 selectableport
-- Operating Temperature : 0 ~60oC( CPU needs cooler )
-- Relative humidity : 5 ~95%, non-condensing
Includes the following
--pIII 1.0ghz cpu
--128mb ram
--Aitech PSC-2000 vga -> ntsc scan converter (VERY good)
--Full wafer wiring kit serial, vga, audio, ide, usb extender, ps/2 splitter.
--IRman IR receiver (serial)
looking for $350 shipped anywhere in the us
8 Pictures available at:
http://ryan.dirocco.org/pictures/ebay/wafer/
Specifications
-- Super I/O :
-- --> IrDA
-- FDD : One port
--pIII 1.0ghz cpu
--128mb ram
