AcidicRage
- Jul 18, 2002
I know there's many way to do it, but I find some ways easier and better than others. I know of several ways including putting a tiny dab of paste on top of the CPU, then spreading it evenly or just putting a dab, and allowing the HS to spread it as you push it down.. Well, here's how I do it: first, clean the stock paste on the HSF with something like ArcticClean, then I put a very small dab on the bottom of the heatsink, smear it just a tiny bit. Then I put a tiny dab ontop of the CPU, and put the HSF onto the cpu. I like to smear a little on the bottom of the heatsink, but not on the CPU because I want the HS to smooth it out as it sits ontop of the processor. Anyways...I just had some few questions for y'all..
1. Does the thermal paste need to cover 100% every perfect square inch ontop of the CPU? Or only the middle section? Because I never smear mine on the CPU to cover it. I assume (from the ArcticSilver instruction site) that only a certain portion of the middle of the CPU generates the heat...
2. How do you guys usually apply YOUR thermal paste? List the steps. =D
