Hello!
I'm going to set up a brand new configuration, based on an I5 13400f CPU and 32GB RAM, and I'm still very hesitant about the choice of graphics card...
My uses will be:
- Flight Simulator 2020, Cities skyline, some FPS, possibly Cyberpunk and Ratchet
- as a beginner in Unreal Engine 5, I'd like to create projects such as virtual house representations and small games
all on a 1080p screen for now anyway!
I also have an Nvidia shield under android for watching TV and eventually want to stream my games from my pc to this box.
There are 3 cards in my budget (+/- 300€) in my country:
- RTX 4060: which is a card very often offered in mid-range configurations, compatible with new technologies, but perhaps too limited in RAM (for UR 5, for example?)
- RTX 3060 12GB: "old card", but seems to be very good for most 1080p games, and above all has more RAM (for UR5, for example).
- RX 6700 XT: I don't know AMD (I still have a GTX 570-based config...), but it seems to outperform the other two, but I don't know if it's a good choice for 1) UR5 and 2) streaming games to an nvidia shield.... (although there are other solutions for streaming?)
Anyway, I'd love to hear any advice you may have!
My uses will be:
