Domingo
- Jul 30, 2004
With more people moving to the platform and so few motherboard reviews these days, it's nice to see something like this.
B650 Motherboard Roundup - Techspot also craps on lower end Asus boards:HUB liked a few gigabyte boards; of course, their ratings have nothing to do with customer service or return difficulty. If anyhting, they dumped on some of the lower end Asus boards.
It looks like Asus may be past its prime.Then, we have the Asus Prime series, which includes the Prime B650M-A WiFi, Prime B650-Plus, and Prime B650M-A WiFi II. Unfortunately, we must recommend avoiding these. Like the ultra-affordable Gigabyte B650M K, the Asus Prime boards all use discrete MOSFETs, resulting in poor VRM thermals.
Yeah, I'd be tempted with the Gigabyte boards that was at the top of their charts/benchmarks - the low temps were intriguing - but, I'd be reluctant to pick one because of Gigabyte's RMA controversies and the rep of their poor CS. I'd want to look at reviews and how many have been returned/RMA'ed.... I also would be really hesitant to choose one early on in the release - yeah, if they've been out for a while and there's few issues - that would make it easier.Techspot is just Hardware Unboxed's normal website isn't it? Either way, it feels like ASUS's lower end stuff is garbage, but the mid to high range stuff is still solid. If I had to go low-end, I'd choose ASRock. That's where they cut their teeth. As much as I like Gigabtye hardware, I despise their software and support. I still consider them the "if no other OEM's have something viable" option.
I just bought a Best Buy combo with this Aorus Elite AX board and it says I payed $154.99 new and $134.99 for the 7600x new with Starfield for free, so I guess Hardware Unboxed will need to adjust pricing pre frame!I ended up with the Aorus Elite AX after looking at that info. It was cheaper than the MSI boards and got it open box on Amazon for something like $140. Good enough for a 7700x. I'll probably upgrade to a different motherboard when Zen5 comes out anyway.
If you bought a solid one to start I don't see why not at this rate.Interesting that the second round of these boards are mostly trash. It'll be funny if the first batch of B650E boards (and lower-tier X670E) end up carrying most people through the end of the AM5 era.
