Mad Maxx
- Apr 12, 2016
Yeah that grille definitely ain't sticker friendly. Those you pointed out are worth a shot. It's only a few bucks to risk.I had seen versions of those type of feet, problem I have is that the bottom of my laptop has the vents back there and there is little room to adhere them to the bottom. The feet I got are a little problematic finding the right place for them at first but once I do find the right placement I don't have any issues with stability uunless I need to move the laptop for some reason which is rather rare for me. I do think I may revisit the possibility of getting some stick on feet. I think if I get some about 1 inch wide they would fit between the fan grill and the edge of the bottom.
[edit] Just measured with a some calipers and I have about 0.8 inches between the outside holes and the edge of the bottom, but it would not be a crime if I do hang over the first line of holes to get something to fit. Looking at trying THESE maybe, they are 1.17" wide???
