Hardware components in sig, so I'll just elaborate on the new cooling.
Before:
Dual Bayres > D4 > Dtek WhiteWater > BIX > Maze4 > BIX > Dual Bayres
Now:
dual bayres > D5 > D5 > Storm > Maze 4 > EK NF4 > PA120.3
Ambient temps stay between 20 and 22c.
** Before Temps **
CPU Load - 45c
GPU Load - 44c
NF4 Load - 52c
**After Temps **
CPU Load - 38c
GPU Load - 38c
NF4 Load - 39c
Substantial improvement, and glad I upgraded. Before the upgrade, I couldn't get CPU-0 to stabilize under any conditions. Now I am able to get both cpu's 24/7 dual-prime stable and SuperPI @ 2700mhz (1.65vcore)
The EK NF4 chipset block was a great addition. Dropped my chipset temps by 13c. The PA120.3 radiator completely stomps my two BIX's I had. I added a block, and the temps are still down on the cpu and gpu. No small feat considering how both the cpu and gpu are running at 1.65 volts on their respective cores.
*** On with the pictures! ***
Prepping the board -
All the blocks, mounted neatly on the sli-dr and X850XT. I put one of my custom brackets on the Storm. Polished to look like my UFO case. -
Gotta love the sight of a NEKKED X2 -
Motherboard tray modification. Figured some airflow behind the mobo couldn't be a bad thing -
EK NF4 Block mounted. As you can see, this block wasn't really made for big bore systems. Mounting was a little tricky, but was functional. Had to use 7/16"ID tube on it to get a snug fit, and to allow for zip-tie hose clamps.
The dual D5's, after being painted and mounted -
The PA120.3, after being painted and mounted -
Almost done! Just need to order two more 120mm galaxy fans for the front and mobo tray exhaust. I like it!
In the dark -
Used Hydrx for the green in the water, in case some of you were curious. Also mounted a floppy drive behind the mobo tray... since there wasn't anywhere for one on this UFO. My next case from them will have one built in. All in all, I'm happy with how it turned out.
Before:
Now:
** Before Temps **
CPU Load - 45c
GPU Load - 44c
NF4 Load - 52c
**After Temps **
CPU Load - 38c
GPU Load - 38c
NF4 Load - 39c
In the dark -
