best software for benchmarking--- Storage / Memory / CPU / GPU ?
IAmForum
I currently am using
cinebench r23 (cpu)
unigine superposition (gpu)
crystaldiskmark (storage)
userbenchmark (memory)
are there better alternatives for benching ?
my scores for
crystaldiskmark (up to a 2x difference from 2 run one right after another)
userbenchmark (the scores can be pretty varied - maybe 25%)
can have major differences from one test to the next
I get decent results back to back with crystaldiskmark on my systems.
When you say 2x difference, do you mean like 5000 on one run and 2500 on a second run?
Pretty much.
one run I might get 1500 and the next run will get 750.
I guess if you are doing an NVME or SSD back to back, it might be a heat issue or cache not clearing issue if the second run is slower.
Any opinions of what CPU benchmark gives the best indication of a real life comparison from CPU to CPU?
If for gaming tests is it just best to take a popular GFX benchmark and run it at the lowest possible rez?
