This does NOT apply to everyone. I'm just informing people so that they can check and prevent a potential issue from arising.
Apparently there is a problem with a batch of Asus K8V Deluxe motherboards that went out with S/N's ending in the 3000's.....so check your serial number and if the last for digits are 3XXX then check your capacitors!
There have been MANY boards (at least in the GTA/Greater Toronto Area) that have been DOA with busted/burst capacitors bubbling, leaking, or some that worked fine for awhile and then bust.
So check them out. The capacitors that have been blowing in 95% of all cases i've seen are the capacitors right aroudn where the memory slots are.
Don't get all worried, as I said, this does not apply to everyone, but if you have a board with this S/N, or close to, just check it out.
EDIT: Also, meant to say that Asus has made a "Silent Recall" on some boards...in other words, they aren't doing anything about it unless they are approached by a consumer/supplier.
