Keyboard not waking PC from sleep - what setting am I missing?
ss88
New build running Windows 10. When PC is asleep, keyboard and mouse will NOT wake the PC. I'd like keyboard to wake PC. I have the usual settings correct:
1. in Device Mgr > keyboard > Power Management > check box "allow this device to wake the computer"
2. in Power Options > Advanced Settings (for the power plan in use) > Sleep > disable hybrid sleep
What else should I check?
Check that wake from kb is enabled in bios. Think microsoft overrides that anyway, but if not then enabling it may help.
Also, I think you cannot have c-states disabled in bios, so make sure that's set properly.
Reactions: ss88
You are correct, I just had to enable USB devices in the list of things that could wake the PC. Thanks.
I am having the same problem as ss88 about not getting the PC to wake up. Work fine till I hooked up my new kb & mouse.
I just received my new Dell KM7321W keyboard & Mouse. I have programed a key for sleep which works
great, but can't seem to figure out how to wake? I am running Win11 pro.
I have the same settings checked as ss88 but I can't get anything to wake this pc.
I did go in Bios and made sure the wake from keyboard was enabled. What I replaced was an old ancient
Microsoft office PS2 keyboard and had no problems wakeng with that one. I have the dongle plugged
directly into a usb slot on the pc. It is not plugged into a hub or anything.
I do notice that under Device Manager it shows two instances of HID Keyboard Device and two for HID-
compliant Mouse, however only the top one has the Power Management settings, on the other one that
setting is missing on both. Could it be possible that this new keyboard combo won't wake my pc?
PS: I also had the kb & mouse connected via bluetooth and that didn't work either.
It's not a game changer but I'm so used to just hitting a key to wake the PC now I have to open the
cabinet door and push the power button.
Thanks in advance for taking the time to read and respond.
