Dynex @ 13c per kwH - as of 5:44pm, 3/9/2023
atp1916
[H]ard|DCoTM x1
If you got an AMD RDNA3 79xx card, you better be gettin that.
Even the RDNA2 stuff isn't that bad.
Not to bump my own thread, but, my fleet of 40 3060 Ti, 16 3070 Ti, 5 3080, 8 1660 Ti net a whopping ~8USD a day profit.. /rip
Edit - as of the time of this post.
likely less than that, multi-gpu builds more-or-less require a modern (AES instruction set) 4+ core cpu to hit 1:1 reported/pool hashrate. Only reason this coin isn't getting hammered into oblivion by hashrate is because of the zillions of 6+ gpu celeron rigs out there.
This is true on the CPU requirement. My boxes are all 6500T / 6600K builds fortunately. The one test bench board I have that does use one of those garbage integrated Celeron "lite" chips was 100% util on 8 3060 Ti with a ~30% penalty on the hashes.
However, and the reason i made the thread here was that until now, there was no way to mine AMD cards on this coin. Now, yeah, i feel it will get hammered into the ether. AMD stuff seems insanely efficient on this coin all told w/ the SRBMiner.
