chameleoneel
- Aug 15, 2005
Hey All,
The redemption codes for AMD's AVATAR: Frontiers of Pandora promo, are split between CPU and GPU. If you got a GPU code, it likely won't activate with a CPU. If you got a CPU code, it likely won't activate with a GPU.
I got a GPU code (with a legit purchase I made from Best Buy) and tried to activate it with my already built 7800X3D system, doesn't work (Purchased GPU is not yet installed). Had another person try it with a 7800X3D system, also did not work. According to the promo info, 7800X3D should work. And nowhere in the fine print, does it say the codes are split between hardware.
I opened a ticket with AMD and they confirmed the reason:
