Hello everyone,
I recently built a pfsense firewall box out of this case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811152107
and this motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813182234
This is my second case as i RMA the first one thinking i had a bad power supply. Doesn't appear to be the case as my second power supply in the second case doesn't spin either.
The system boots perfectly fine. Pfsense is loaded on the hard drive and functions. Just the power supply fan doesn't spin.
Thinking i possibly have something wired up wrong.
A pic of wiring.
http://i1211.photobucket.com/albums/cc427/jeremyjd10/Pfsense Build/IMG_0301.jpg
Only cable plugged in our the sata and ATX 20 pin power adapter on motherboard.
Any help is appreciated.
A pic of wiring.
