Mark660 , where do you get the antec 900 with black colour inside ? i wanna get this case for my 2nd rig to , the dark colour inside looks pretty good , where can i get thet? or is it custom?
My old antec 900, now a TJ07, for obvious reasons
*snip*
wow your blue paint...it's to bright darken it a little
Plastic over the fan grill
Haha yeah, I took it off soon after. I just wanted to savior the dustless-ness of the side window as long as possible. Roger, cut 4 holes but ended up only using 3...IDE cables couldn't reach all the way across, but I may invest in some 24" some time later to get rid of the purple abomination crawling ontop of the PSU.
Oh, and yeah, this thing is one BIG dust magnet.
Just some cable management:
<pic snip>
wow that is real nice, makes me want one
I installed fan filters on mine, and it's clean as a whistle.
l
Which fan filters did you use?
