Ciggarilo Himself
- Nov 22, 2006
Is 1.5gb enough memory to turn off file paging? or am I better off getting another 512 stick?
1.5gb is pretty smooth for me.
Thanks
Thanks
As I recall, Windows will always make a paging file of some sort, even if you think you've disabled it. In any case, I run it in "System Managed Size" on both of my computers- a 1.5GB notebook and a 2GB desktop.
(3) Delete the c:\pagefile.sys
Ah I should've mentioned, it's a hidden/system file. You'll need to attrib from the command line or set explorer to view hidden/system files.
You don't have to be in safe mode, but believe me booting in normal mode with no page file sucked when I first started using this method, so I've stuck with it (Win95, 64MB of RAM.)
Hmm, i'm at a complete loss. I checked the location of the pagefile.sys file in the registry and it is just on the C: drive, but no matter what i do i can't see it.
Make sure "Hide protected operating system files" is uncheck along with the hide hidden files and folders option.
To see pagefile.sys,do the following:
Tools > Folder Options > View
Make sure that you hae selected "show hidden files and folders" AND uncheck "hide protected operating system files"
Then you should be able to see pagefile.sys in your c:
EDIT: Whoops a couple mins too slow
