The reference 1080 does have 5 outputs -- 3 DP, 1 HDMI 2.0, and 1 DVI-D.
Can all 5 outputs be used or are some disabled. Like if you use the HDMI does the DVI become disabled?
No analog on the 10x0 cards though whereas the 9x0 cards do though I doubt anyone cares much.So looking at the 1070/1080 card coming out it looks like the outputs are the same as the 970/980 cards.
All the official specs say is "DL-DVI;" they don't say DVI-D like the OP does. The DVI output on GeForce cards has historically been DVI-I. If it still includes an onboard RAMDAC(s) that means you should still be able to get an analog signal.No analog on the 10x0 cards though whereas the 9x0 cards do though I doubt anyone cares much.
One of the (many) articles noted it was DVI-D only.
On a side note, it is seriously difficult to google the 1080! Such a stupid name.
Not anymore: R.I.P. VGA: Nvidia's GeForce GTX 1080 dumps analog support, following Intel and AMD's leadAll the official specs say is "DL-DVI;" they don't say DVI-D like the OP does. The DVI output on GeForce cards has historically been DVI-I. If it still includes an onboard RAMDAC(s) that means you should still be able to get an analog signal.
Well, crap. I guess the dinosaurs that are still left out there need to move on.
Well, you can get an active converter if you still really need VGA. DVI-D to VGA Active Adapter Converter Cable – 1920x1200 (available cheaper elsewhere)Well, crap. I guess the dinosaurs that are still left out there need to move on.
4 port VGA KVMs can be had for less than $40. DVI/HDMI/DP KVMs are 4x as expensive.
I have an active converter for my laptop since it only has a microHDMI and I need VGA to connect to projectors at customers.
It will most certainly work. They're saying you can't use one of these: DVI to VGA Cable Adapter - M/FSupposedly that will NOT work with the new cards.
Pascal Secrets: What Makes Nvidia GeForce GTX 1080 Fast?
Search for performance lead the company to remove as much legacy options as possible, and you can no longer connect the GTX 1080 with an analog display. D-SUB15 is now firmly in the past, and you cannot make the connection work even if you use a 3rd party adapter. The rest of connectors include a 144Hz-capable DVI, three DisplayPort 1.4 and a single HDMI 2.0B connector.
If it is blocked, I bet it has something to do with that HDCP or whatever DRM on 4K Netflix movie streams. That's my opinion of course about the DRM.
Can't you get a DP -> dual link DVI-D adapter? It'd have to be active, but I'm pretty sure they exist.I'm assuming the DVI port is a dual link port, correct? What are the chances of seeing a 2x dual link DVI card like the gigabyte windforces?
Technically you could get a passive cable or adapter, but dual-mode in the DisplayPort connection only allows for a pixel clock of up to 300 MHz from the source. That means either you're limited to a maximum of 1920x1080@120 Hz or 2560x1440@60 Hz.Can't you get a DP -> dual link DVI-D adapter? It'd have to be active, but I'm pretty sure they exist.
I don't think you can get a passive DP -> dual link since SST DP doesn't have enough differential pairs.Technically you could get a passive cable or adapter, but dual-mode in the DisplayPort connection only allows for a pixel clock of up to 300 MHz from the source. That means either you're limited to a maximum of 1920x1080@120 Hz or 2560x1440@60 Hz.
That's what I mean. Dual-mode DP only support single-link DVI over a passive connection. I may have been wrong about the supported resolutions. It's been awhile since I've had to look at the DVI specification.I don't think you can get a passive DP -> dual link since SST DP doesn't have enough differential pairs.
Gotcha, but active adapters do exist to spit out dual link DVI-D. I found a few via Google. They're not cheap though.That's what I mean. Dual-mode DP only support single-link DVI over a passive connection. I may have been wrong about the supported resolutions. It's been awhile since I've had to look at the DVI specification.
