Bio-Hazard said:Overkill is good............ I'm running a 120.3 and a 120.2 in my system. And I'm only cooling a CPU and single GPU............
Been there done that, tested it several times in several differant configs with numorous pumps and radiators and heater cores and fan combinations not to mention Storm,APOGEE, Polarflo and Danger Den CPU and GPU blocks. Been doing this for more than a day or 2 now........ I've even ran it with 3xD5 pumps at one time, but that was really over kill. My rig works best the way it's setup now.............ElMoIsEviL said:That's overkill. In fact you may be hindering performance. Watercooling is an art. You need to ensure you do not hinder your waterflow too much.
The more rads the lower waterflow.. add a few restrictive blocks (like you Swiftech Storm.. which is one of the industries most restrictive blocks) and the added benefit of an extra large Radiator is lost.
There is a solution however, you can run pumps in parallel or in a daisy chain. Ensure the pumps are not working closely to each other (meaning ensure there is a good balance of restrictive components between each pump).
But probably not, unless the pump is fairly weak.ElMoIsEviL said:That's overkill. In fact you may be hindering performance. Watercooling is an art. You need to ensure you do not hinder your waterflow too much.
