WhyYouLoveMe
- May 24, 2005
After reading a few disturbing reviews showing the 175.19 drivers performing much worse than the 175.16 I decided to do a test myself. The review sites use newer hardware than I have so I didn't know if their numbers applied to my situation. FYI I use DriverCleaner Pro after each driver change.
System Specs: Athlon X2 4800+ @ 2.72ghz, 2gb Corsair @ 227mhz, EVGA 8800GT KO @ stock (675mhz/1950mhz) with Accelero S1 passive, SB Audigy 2 ZS, Raptor 150, Windows XP Pro SP2 32-bit
Benchmark: Crysis @ 1280x1024 most settings high with some medium, no AA and no AF
175.19: Avg. 36.41, Max 43.91, Min 21.42
175.16: Avg. 38.87, Max 46.24, Min 20.98
There you have it. The 175.16 driver runs better on my system in Crysis, too!
I also played some Cod4 but I don't have a detailed benchmark comparison. I looked at the FPS number while playing it through the same spots and noticed the 175.16 FPS were a couple higher. Obviously this could be subjective so take it for what it's worth.
Hopefully this is helpful to others who have a similar setup.
Review link: http://benchmarkreviews.com/index.php?option=com_content&task=view&id=194&Itemid=1
