Chris Lakies
- Feb 17, 2005
See Title. I tried the in game AA control = no luck. I also tried forcing through CCC = no luck.
What the hell no AA in BF2 for me?
gersson said:The fact that you have AA enabled through CCC is the reason why it doesn't work. Leave it to application preference. That will do the trick.
texuspete00 said:Ok. But for future reference this is true for BF2.
Catalyst AI disables your forced AA if the game has issues with AA. You could get around this by disabling AI. Then you can see for your own eyes what the issue is. I had the issue with Nv too. There can be like a funny line like your screen isn't lining up right. For my nv, it was a thin red bar running along the left side and top only. The soluton in this case is to simply use the game AA instead.
