kharan5876
- Oct 3, 2007
I have a 1U server that I am planning to have running all the time.
It is a socket AM2 motherboard and I am running a 65W Athlon 64 X2 4400+
I currently have this cooler
http://www.ncix.com/products/index.php?sku=25585&vpn=A48G&manufacture=DYNATRON
it is nice but loud as hell I wanted to find a new quieter solution.
The 4 solutions I have found so far are:
Buy an aluminum heatsink with fan
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=157&products_id=23447
Not too expensive
Says it is designed for using mobile cpus
I have a blower blowing onto the cpu from the edge of the motherboard
Buy a passive heatsink
http://cgi.ebay.com/A46G-AMD-Socket...3044156QQcmdZViewItem?_trksid=p3286.m20.l1116
I have a quiet blower in the case thats blowing right onto the cpu, so this could potentially work. Still, I really care about cpu lasting a long time so I wouldn't want to push it.
Or do you all think this wouldnt be a bad idea if I test it and make sure the temps dont don't go too hight?
maybe it wouldnt be worth risking it, I care about hardware lifetime more than anything else.
Use a fan control knob to reduce the power to the cooler I already have and hopefully make it quiet enough for max load
I have one of these knobs already
Don't have to buy anything
Will this cause problems with the bios/os trying to change the fan speeds?
Will this wear the fan out?
Buy a copper cooler with fan
http://www.startech.com/item/FANK8AM21U-1U-Low-Profile-Socket-AM2-AMD-Heatsink-with-Fan.aspx
Probabily the best cooling of all these solutions
expensive
Rated at 36DBA, louder than the aluminum one
Does anyone have any suggestions? Thanks for looking at this
Not too expensive
expensive
