candy76man
- Jun 9, 2003
I'm putting together a media server with four drives for storage that I am going to span together.
I bought two two channel ide cards so that I only have one drive per channel.
the problem I'm having is that when both cards are installed windows won't start (or install for that matter)...if I remove one of the cards everything works fine...any idea why I can't start windows with both cards in the pci slots?...the mobo (Abit KT7) boots just fine with both in and they both pop up the little detection screen and see all four drives but after that when windows should start loading, the screen just goes blank and nothing else happens.
I can't imagine xp would limit it to one addin ide card would it?
