Originally had 2 water loops
1) CPU + Southbridge
2) 2 GPU's + Northbridge + Voltage regulators
got 2 GTX 260's and decided not to water cool them. Reconfigured the loops to be :
1)CPU
2)Northbridge + Voltage regulators + Southbridge
Discovered due to Southbridge water block, I am forced to take the stock cooler off in order for the Vcard to even fit!
So now I'm wondering: I really like the CPU being on it's own loop, but I'm afraid 2 GPU's, NB, SB & VR on one loop is just too much. Is it? I'm using a Chevette heater core that has exact same surface area as the (4) 80mm fans on it. If you think all that is too much for one loop, what is the coolest device I should put onto the CPU loop?
I'm guessing either VR's or SB or both. Thanks in advance
1)CPU
