Hi all,
As many people, I've been waiting for maaaaany years now for a decent 24" monitor...
I've been checking a lot of posts on this forum for some months now and I still havent decided which one might be worth it.
Because at the moment, all info is spreaded on millions of pages in thousands of posts, I would like to use this thread to make summary of all interesting 24" models with their upsides, downsides and how they compare to each other if that info is available...
I'll try to keep this thread up to date by including the info you guys reply
First I'll just start with listing the interesting models and some basic info:
Dell 2407WFP rev 3 or earlier
+ good price
+ lots of inputs
- color banding
- crappy hdcp chip that hardly supports hdcp for the higher resolutions
- aspect ratio issues
- cheap components
Dell 2407WFP rev 4
+ good price
+ lots of inputs
- still has scaling issues (you need to go to a non native resolution before scaling options become available)
- cheap components
NEC 2470WNX
+ good components
- not available in benelux (europe?)
Benq FP241*
+ ok colors
+ ok response time
- blackouts
- still no firmware update to fix all aspect ratio issues
- bad support
Eizo S2411*
+ good colors
+ good comonents
- only 2 dvi outputs
- high price
this is just a start, i dont have any 24" yet, so mistakes are possible, plz correct me if needed
+ good price
+ lots of inputs
- color banding
- cheap components
Dell 2407WFP rev 4
+ good price
+ lots of inputs
- cheap components
NEC 2470WNX
+ good components
Benq FP241*
+ ok colors
+ ok response time
- blackouts
- bad support
Eizo S2411*
+ good colors
+ good comonents
- high price
