silentsammy
- Feb 4, 2006
I didn't notice any posts on this, but I just saw this for sale on the Egg:
26" Acer LCD for $749
Any thoughts?
Any thoughts?
Seanmounce said:I noticed it, and I want one. My 19inch somehow isn't enough anymore...
Games now, yes I think it will play them with at 30fps (min) with settings high but don't bank on it running Crysis like thatp-n-p said:will one 8800gtx run this smoothly while playing games?
What are you basing that on?ToastyX said:This is very interesting. The only possible panel this could be is one of those new A-TW H-IPS panels, the same one being used in the 26" NEC
Good excuse to buy second GTX!artmonkey said:Games now, yes I think it will play them with at 30fps (min) with settings high but don't bank on it running Crysis like that
I thought that too, but I was unaware of those other panels. I'm not sure they're available yet, but if they are, it's most likely the P-MVA panel. The specs seem to match the LM260WU1 panel the most though, but specs can lie.artmonkey said:What are you basing that on?
As far as I can see it could also be one of these panels:
AUO's 'M255UW01 V0' (P-MVA)
CMO's 'M260J1' (S-MVA)
Personally I doubt you'll get an LG Phillips 'LM260WU1' (A-TW IPS) for that money.
I just saw this as well, and gravely considered putting it into my Core2 Duo wish list...silentsammy said:I didn't notice any posts on this, but I just saw this for sale on the Egg:
Any thoughts?
WickedWeasel said:Good price on ncix canada!
Trying to decide on a LG or NEC 22in S-IPS vs. 26in S-IPS? for a similar price.
What is better for games in terms of image quality?
22in with 8xAA or 26in with no AA?
I like the thin bezel but the non-adjustable stand and generally plain styling kinda deflates the erection I get from the size of the screen.JVC said:doesn't anyone don't like the design??
Isn't the NEC 22in monitor going to be an S-IPS panel, or are all the 22in LCDs TN panels?travbomb said:There arent any 22 inch S-IPS. Did you mean 24??
WickedWeasel said:Isn't the NEC 22in monitor going to be an S-IPS panel, or are all the 22in LCDs TN panels?
