Aelfgeft said:1GB FTW.
fuelvolts said:Why? My chip is OCd to 2.4 using ram divider - would I loose my OC?
(cf)Eclipse said:simple solution. try both and see which performs better for your usage
mikeblas said:Other. I'd rather have 16 gigs of PC3200.
Point is, it depends on your application. Which is better depends completely on your application, budget, plans, existing system, and so on.fuelvolts said:wouldn't we all
fuelvolts said:well here are some results:
3DMark05
1GB @ 2.4 ghz DDR398 (Divider) @ 3 CAS 1T = 3673
2GB @ 2.45ghz DDR271 2/1 Divider @ 2.5 CAS 2T = 3553
hmmm....what should I make of these results?
If you got 'em would you go back to 1GB?
*******************UPDATE****************
2GB @ 2.55GHZ 1.425v unlocked 6800 DDR280 +1v = 3853 (probably most due to unlocking my 6800 OC)
CPUZ validation
http://valid.x86-secret.com/show_oc?id=127888
MetalX said:You doubled your 6800's pipes and it only went up 300 points? I've never ran 2k5 but I figured it would go up more than that.
