Alright Here is my setup...
front intake = Vantec Thermoflow 120mm (temp controlled)
1300-2200 RPM
54.3-92 CFM
29-39 dB
CPU = Scythe S-Flex 120mm (Thermalright ultra extreme 120 heatsink btw w/ my Q6600 running at 3.0GHz)
1600 RPM
63.7 CFM
28.0 dBA
rear exhaust = Antec tri cool
1200/1600/2000 RPM
39/56/79 CFM
25/28/30 dBA
and the 140mm exhaust that is in my new Corsair PSU...it is temp controlled.
Should I rearrange these things? I really don't know that much about airflow and fans. I know I can always rearrange and constantly check temps, but to be honest the way I have my PC in my desk it is a huge pain to take out and put back in its hole
I'm not sure on a temp controlled fan where the best spot would be for it. Fan sound isn't an issue for me as I keep the Antec on high and I keep my 9800GTX at 80% in windows and 100% when gaming and it is louder than all the other fans anyway so I would rather just keep all my 120's going at 100%, 100% of the time.
I was thinking of putting the Antec on the CPU and leave it on high, and putting the Vantec on the rear so I would have both exhaust fans temp controlled, and putting the Scythe up front for my intake...how does this sound to you guys in the know?
1300-2200 RPM
54.3-92 CFM
29-39 dB
1600 RPM
63.7 CFM
28.0 dBA
1200/1600/2000 RPM
39/56/79 CFM
25/28/30 dBA
