Ren H said:Holy superfast reply! You ocing your keyboard? ;-)
ty on reply
the venice E6 is a completely different core from the toledo E6. it would make sense if i knew the part that comes before it, like DH-E6 vs JH-E6 or something like that. either way, i wouldn't bother with any venices other than BPRen H said:I see from the A64 oc guide the E6 are Toledo chips with 1meg per core,
- the core (E6) is independent of cache and available on Venice chips? (Venice are strictly 512?)
There's a retailer locally with the Venice BP, I'm wondering whether it's worth my time hunting down the newer versions or not.
EDIT: just found an Opteron144 E4 I can afford, (extra $25), hmm, now what to do...
Thanks for the help!
ty Eclipse, I hear they oc well so I think I'll go for the Opteron, let the fun begin!(cf)Eclipse said:the venice E6 is a completely different core from the toledo E6. it would make sense if i knew the part that comes before it, like DH-E6 vs JH-E6 or something like that. either way, i wouldn't bother with any venices other than BP
the 144's are fun
(cf)Eclipse said:no, BP doesn't mean box processor. it denotes that it's an E3 revision venice..
the other choices are BW (E6) and CG (E4, a manchester with one core disabled)
honest mistake. it makes perfect sense from an acronym stand pointwee96 said:Woops
(cf)Eclipse said:honest mistake. it makes perfect sense from an acronym stand point
don't fret it
stepping is is and isn't related.Ren H said:EDIT: Found an answer, I believe it refers to E3 core type, this relates to stepping or is stepping independent of this?
