saturnine2 said:The 6800 cards really do kick ass.
DarkT609 said:I got 12136 I think. I will get higher, I hope, when I order new RAM. This 6800 GT is so damn good.
Rizen said:I get 6,596 3DMarks using the new Cat 4.8s (slight 3DMark boost for me) and my 9800 Pro @ 435/400.
Is your Barton or 9800 Pro overclocked? I got most of my performance increase over you from overclocking.
Try your Barton @ 11x200 and OC your Radeon as high as it will go and let know how it goes
My 9800 Pro has a VGA Silencer + OCZ RAM Sinks, however..
You have a Barton core, 150MHz higher clock, and the 200-300 point increase from having an XT BIOS (I assume you have an R360 core?) you should be beating me by more.Roach said:435/400? Might need to do a bit a tweaking. 426/385 got me 6908. You have anything running while you did that bench?
-freon- said:
6800GT owns!
sgi02 said:
System in my sig. 6800 Ultra pwns
Zachary
PimpBot5000 said:3dmark 03 is entirely GPU limited. Cpu's really mean nothing. I've seen asstastic cpu's with a high end GPU score as high as that.
C4rniV0r said:Spend more money
Rizen said:You have a Barton core, 150MHz higher clock, and the 200-300 point increase from having an XT BIOS (I assume you have an R360 core?) you should be beating me by more.
I wish I had an R360 core, I'd pull almost as much as you thenRoach said:As PimpBot5000 put it, cpu doesn't affect the score. I've run these test at 2.0Ghz all the way to 2.6Ghz and only seen 20-50 point difference. For your question though, yes it is a r360 core.
