I am thinking about starting a new thread detailing the 4x 3GB 580 setup and custom sub-zero liquid cooling. Including benchmarks, screenshots, video etc.
You can safely take them over 1.5v. However you shouldn't need to unless you are trying to take it over 5.0GHz. In which case your chip may or may not do that regardless of the voltage. These things have multiplier limits and they'll hit a wall at some point. For those it's usually around 49x-50x
I'm running a beta bios that provides PLL overvolt that is supposed to break through the barrier. I can run at 4.9ghz at 1.42v but it fails out of folding after a while, I've been nervous about giving it more voltage even though the temps max out at about 63C. This processor is at full load 24/7 for folding so I can't use a voltage that is only appropriate for bench runs, have people been running well over 1.4v 24/7?
Yeah I was anticipating temps being an issue with non-ref coolers that jammed together. Interesting you can run Shogun 2 maxed out, I was hearing that the beta was an absolute hog. Still, 57fps on four GTX580s is pretty alarming!
Heh, alarming in a bad way. That's a LOT of graphics power to not quite break 60fps.
Awesome vega!
I'm surprised you can get away with 1.5V on a 32nm chip to be honest, given the voltage tolerances of their predecessors. What's defined as the temperatures 'being in check?'
Is there an agreeable scaling percentage you've come across for Quad-SLI with the 580s, or would you consider it too variable?
I need a watt meter as I hope my solo HCP-1200 is holding up ok. I figure with the OC'd CPU and 4 GPUs I am pushing 1500w and pulling around 1700-1800w from the wall. I had to plug the HCP-1200 directly into the wall as the UPS I was running shut down from overload.
Holy shit man, you don't need a watt meter; you need a nuclear generator..............
Your stuff is way impressive....and the time and energy you've put ito the comparisons is awesome.
Keep up the good work.
You're a sick, sick man Mr. Vega. Love it! I hope to see you run Quadfire with two 6990's and let us know how it performs for you.
Having followed this thread, I doubt he's going back to the amd cards any time soon after finding the 3gb 580's
I'm sure someone will come out with a 4GB version of the 6990
One word of caution though, even if you have a SSD do not disable the page file! I was having all sorts of issues without a page file. Even though I was only using 3-5GB out of 6GB while playing games, tons of games want a page file. I am not sure if its DirectX or Windows 7, but at this high of a resolution there needs to be a page file for some reason.
Yup, even if Win 7 shows plenty of free physical RAM, some things just don't work right without a page file being there. I wonder if the page file has anything to do with pre-loading data for the video RAM, as if I turned off the page file a lot of games wouldn't work properly and I would get DirextX errors, etc.
