Hey guys,
Been piecing together a 4220 build for a few months but am having problems picking a processor (and for that matter mobo). I have included some details about the machine and what it might do below but also am trying to pick a processor with value in mind. Being less saavy than most I figured I'd see what everyone recommends.
Machine's Purpose:
Primary: Movie/File server to multiple machines on local network
Secondary: Serve as a development/beta server for a SQL & PHP based internet site
Future: Virtual Machine host
Goals:
Low power usage (24x7 uptime)
Expandable (would like primary components to last at least 5 years)
I have made a few power searches (ok maybe more than a few) but am still running into the question about desktop/server CPU (by newegg's definitions) and feature set needed.
I have tailored the choices down to about 9 CPU's based on the following limits:
$150 (could consider up to $300 but thought about dual processors)
64 Bit support (no 32 bit limits)
Virtualization Support (not exactly sure if this is an AMD specific buzzword, but being able to possibly virtualize this box is a probable future purpose)
45nm or 65nm manufacturing
And here is what I have come up with:
http://www.newegg.com/Product/Produ...Value=6544:47573&PropertyCodeValue=6544:41825
http://www.newegg.com/Product/Produ...Value=4459:32492&PropertyCodeValue=4459:32490
I would like to keep the CPU(s) and Mobo under ~<$500 if possible.
Other considerations:
Have thought about trunking or NIC bonding for increased throughput and a mobo or expandable NIC might be considered (have a HP procurve 32 port router)
Likely going to go with an single Areca card but am strongly considering using multiple cheaper cards or a chenbro expander. SAS is a must. (for mobo pci slot consideration)
Any thoughts, feedback and or specific suggestions would be greatly appreciated! Thank you for any help you may give.
Machine's Purpose:
Goals:
