looks like the Xigmatek Battle-Axe VD964Here is a picture I found of a HS I haven't seen yet. Just an FYI.
http://www.watch.impress.co.jp/akiba/hotline/20080705/etc_xigmatek.html
http://www.xigmatek.com/product/air-battleaxevd964.php
I used a Arctic Cooling ACCELS1 Rev 2 VGA Cooler on an 8800GT when they came out and it cut the temps in half. Now I keep wondering if my system is running
I have heard that the new one with only 2 pipes is not that good.
I always thought the ones blowing out the back was the best but seems that is getting out of fashion now on aftermarket coolers.
There was a preview/review last month of a new 4 pipe cooler with fans but I can't find it anywhere, DAMN I need to bookmark more. It is supposed to be the best and its also super quiet with its 2 fans. I think the reason I didn't think about it more is that it is not out on the market yet.
The only reason I didn't think about the Thermalright HR-03 GT was it seemed to weigh tooo damn much. BUT I am probably wrong.
The S1 v2.0 still has 4 heatpipes. The one that has 2 heat pipes is the S2 (I know, confusing). The S2 is cheaper and smaller, but not by much. The better buy is still the S1 v2.0
The one with 2 fans & 4 heatpipes is the GFX chipzilla (sp?). The current problem on that on is the heatpipes interfere with the heatsinks on the memory in a massive way.
Hi,
I'm thinking about getting this card but it's hard to go from 42C at idle with my 9600gt to 70i'sh at idle with a 4870 since my room gets so hot anyway. What is the preferred after market cooling gizmo most desired and easiest to install.
I've always had a hard time getting the sheath of nvidia cards, but I'm not sure how hard it is for ATI. Also, I've seen some folks with the duorb vga cooler that looks like it lowers the temps really nicely on the card but will it still heat up the inside of my case like crazy with after market cooler?
I ditched my old 8800gts 640 just because of temp issues and got the 9600gt (which, at less than half the price performs better, heh) so this issue of heat is important to me; important enough I may just have to wait till we start seeing manufactures doing better cooling built on the board if need be.
Advice?
fan speed adjustment won't help when its under load.
it does but for the stock cooling to work as well as a decent aftermarket you have to push the fan speed to noisy levels.
Yes it does.
And? It still works. He didn't say anything about noise.
