for anyone who thinks their computer or video card puts out too much heat, instead of taking stuff back to the store, do what i did instead:
apply some mirror-finish tint to the windows in your room, then put some cardboard cutouts press-fit into the windows to block out the light, in between the mini-blinds and the windows. this way, you can't see the cardboard from either the inside or the outside.
i didn't do this specifically to keep my room cooler, i did it because i work nights, and it keeps my room dark during the day when i sleep.....
but you'd be surprised at just how much heat reduction there is when you do this. i guarantee you, the heat reduction from doing this will MORE than compensate for the extra heat being put out by your CPU or video card.
and even if you only put the tint on your windows in the rest of the house (without the cardboard cutouts), you'll likely find it less costly to keep your house cool during the summer, too....i know i did. it was well worth the time and effort.
