Hi
My memories are running quite hot and I found a way that will lower the temps by putting some of these http://www.newegg.com/Product/Product.aspx?Item=N82E16835118220
Now the question is which way is the best solution to run it cool?
This http://www.sweclockers.com/upload/gallery/20009-full.jpg , without removing the upper plate
or without the upper plate? http://www.nordichardware.com/image3.php?id=5339
Before you write!
Be sure what you are writing!
Before you write!
