There's usually no significant difference, however systems tend to overclock better when using two sticks rather than four.
That is exactly my experience with ram
There are some P965 boards that only function properly at 667MHz with 2 gig sticks. P5B series is one.
2x2GB > 4x1GB. The fewer sticks the better.
That may explain why my P5B Deluxe won't overclock my Q6600 for crap with 2x2gb installed. I may just have try 4x1gb and see if I get any better results. Although even with FSB 333 and ram at 1:1, this POS board has issues. I know the CPU is good for at least 3.2ghz in a G31 board.
Or maybe it's time to ditch the P5B Deluxe altogether.
Not neccesarly. You could oc 4x1gb of D9 to at least 600mhz. It would be very rare that you could do that with 2x2gb. You can do it with 2x2gb if you get very lucky or you buy the $300 2x2gb PC2 9600 GSKILL Kit.2x2GB > 4x1GB. The fewer sticks the better.
I takes a decent board to oc 4 sticks.Some boards have stability problems with 4 sticks of ram
Yea D9There are quite a few reports of certain ram consistently failing in some boards, even using 2 slots but much more for 4 slots.
This can result in having to use low clocks/higher latency settings/higher voltage or replace the ram.
You lose dual channel memory controller capability in that scenario.
Don't know how big a factor that is on the motherboards themselves, but it certainly made a difference in systems based on AMD 754 cpu's vs AMD 939 cpu's.
The fact that the mem controller is not on-die with pre-i7Intel systems may make that a moot point, or at least not one that's noticeable apart from benchmarks.
you only lose dual channel with 1 or 3 sticks
Sorry, brain fart.you only lose dual channel with 1 or 3 sticks
