I used to accomplish 5.1 gaming by running a bunch of cables and adapters from the separate channel outputs on the sound card to the multi channel input on my receiver.
Due to issues with noise plus the mass rats nest it created I have done away with those cables and have a single TOSLINK going from the onboard audio to my receiver.
No more 5.1. I have tried connecting an HDMI cable to the receiver (to try 5.1 PCM) but I can't get a nice 1:1 pixel mapping signal from the HTPC to the TV this way (TV sees 1080i instead of a computer signal so its scaled wonky and colors are all wrong and it just looks like garbage). Only way to get a nice signal is direct to the TV. Can I split the output from my HTPC so that my receiver can do audio and TV still gets the direct signal?
I also have been looking at sound cards that can do Dolby/DTS encoding but everyone I find now is discontinued.
Equipment is as follows:
Custom HTPC
2600K @ 4.5GHz
Maximus IV gene-z/gen3
Asus DirectCU II GTX 670
240GB Samsung 840 Evo
Yamaha RX-V661
Emotiva UPA-2
Paradigm Monitor 11 towers (fronts)
Paradigm Center 3
Paradigm Atoms (rears)
Paradigm SE10 (sub)
Custom HTPC
2600K @ 4.5GHz
Yamaha RX-V661
Emotiva UPA-2
Paradigm Center 3
Paradigm SE10 (sub)
