I know manufacturer is recommending a 600w, but all I have on hand is 500w Antec.... It should just make it... I am not running anything else in the system, just hard drive mobo CD drive RAM, everything stock speed. Can I get away with this?
It's a Antec EarthWatts EA-500D Green 500W ATX12V v2.3
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371035&Tpk=N82E16817371035
Thanks guys, had a friend INSIST i'd need a 600w, now i can tell her nope, (BTW it's an intel sandy bridge 2500k, all stock clock)
What is EBIL? Did you meant to say evil? I wanted stock clocking because it's a Hackintosh rig, and the last thing I need is OC instability at this time. I bought the K version because it was only a few more bucks than the non-k and it has the intel 3000 built in which is hackintosh supported (where is the HD 2k is NOT!)...Stock clocking a 2500k is EBIL!!!!
Depends on what revision you have. if it physically looks like the one on newegg's site that you linked then that appears to be a delta made unit.Ok, so I double checked the power supply, and it's not an EA-500D, it's a regular EA-500 ( http://www.newegg.com/Product/Product.aspx?Item=N82E16817371007 )
I noticed it said 500w max not continuous. Am I still OK?
Id At least run a 750 bud. At least. and a good one at that.
when it's squealing it's only pulling in about 230w on the kill-a-watt... lol cheap psu?
EDIT: what are the symptoms of an insufficient PSU anyways?
That is incorrect.- Squealing sounds, and when sounds gets louder under load.
- Rattling noises.
That is incorrect.
Coil whine is very common, and it's not indicative of a dying PSU, it can have a myriad of causes, from poorly wrapped coils to an EMI soaked circuit... sometimes it goes away on its own.My bad, the two above identifies a faulty PSU or one that is going out.
