ivandurago
- Jun 5, 2008
1) What will you be doing with this PC? Gaming (World of Warcraft/ Starcraft II)
2) What's your budget? $550 w/ shipping
3) Where do you live? Bandera, Texas (perhaps could go to Frys in Austin)
4) What exact parts do you need for that budget? CPU, RAM, mobo, video, power, hdd, maybe a case
5) If reusing any parts, what parts will you be reusing? maybe a case, monitor, keyboard, mouse, maybe a HDD
6) Will you be overclocking? perhaps the cpu/ video in the future
7) What size monitor do you have and/or plan to have? small crt atm, 22-24" in the near future
8) When do you plan on building/buying the PC? If a good build can be done for less than $550, then in the next week.
9) What features do you need in a motherboard? nothing special
10) Do you already have a legit and reusable/transferable OS key/license? x64 win7 already owned
This build is for my best friend in Texas who has not built a PC in the last several years. I believe his last system was a socket478, 9700pro and 1gb of ram
I believe he could get a amd quad core, 4gbs of ram and a 5770/460 for around $550, hopefully. Would consider getting a case if there is a good package deal at Frys/neweeg where the case is nearly free w/ a power supply or something. Please give any advice you can, as he has not built a PC in a long time and would love some great advice.
ram - $55 (4gb DDR3)
HDD - $55 (1TB Black/ Spinpoint F3)
cpu - $100 (AMD quad)
mobo - $100 (890gx?)
video - $180 (6850 or 6870?)
power - $60 (?)
power - $60 (?)
