I have come to my wits end on this thing. At this point I have replaced everything except for the video cards so really there is nothing else to do but buy a new video card. But I figured I would post this up anyways to see if anyone had any ideas or had seen this before.
Let me start with my initial configuration:
Gigabyte GA-Z68XP-UD3P
Intel i7 3770K
ASUS GTX Direct CU II TOP 670 x 2
16GB DDR3 G.Skill Sniper 1600
Corsair HX850 PSU
HP ZR30w LCD & Dell 2007FP
The issue only happens when I play BF4. The machine will either blackscreen and then reboot or I will get a Windows error alert and if I can alt tab I get the various errors similar or the same as the ones below. The errors are not always the same, but I have seen the insufficient memory a few times. I am able to play other games Skyrim, Dirt: Showdown, Diablo III RoS. Skyrim to me is just as graphically intensive as BF4 and I am able to play that no problem.
I have done all of the following for troubleshooting:
Fresh install of Win 8.1
Fresh install of Win 10
Fresh Driver install
Rolled back to previous drivers
I keep my games on a separate SSD and generally point the client(Steam, Origin or Battlenet) to the secondary drive. Saves me from having to redownload everything.
Nuked my game files after a fresh OS install and downloaded everything again.
Updated/Made sure my directx is up to date
Updated Punkbuster
Tried each video card individually
Tried different combinations of pci-e power cables
New mobo, CPU, RAM and RMAd my Corsair PSU
The reason I even RMAd my PSU was it seemed like when I used a certain set of pci-e power cables on a single card I would get the reboot.
My upgraded setup is now:
ASUS MAXIMUS VII GENE
Intel i7 4790K
Refurbed - Corsair HX850 PSU
24GB DDR3 G.Skill Sniper 1600
Like I said above I think I am pretty much looking at a new video card(s), but just wanted to see what the folks of [H] had to say or if there is anything else I should try before dropping $600.
Intel i7 3770K
Corsair HX850 PSU
Updated Punkbuster
Intel i7 4790K
